- Biloxi
- MS
Diff cover and gasket on:
Rear brake lines reassembled and bolted back down:
Rear brake parts reassembled, both sides:
Drilled out the four busted screws, re-tapped the holes in both rear wheel hubs:
Oiled the hubs/shafts/threads/washers/nuts, reinstalled rear axle hubs. Initial hit with the impact, almost to 1-5/16":
Reinstalled rear tires, took it off the jack stands:
Torqued to 250 foot pounds, 1-5/16", holes lined up:
Adjusted brake shoes, finished with the rear end, finally/hopefully (need to refill diff with oil, bleed brakes):
Going to start on the front wheel bearings/spindle bearings/u-joints/brakes/etc tomorrow, that's it for now
