"After having a very informative conversation with fellow member Randyzzz I am rethinking my transfer case choice. Seems the NP 241C (passenger side offset)TC bolts straight to the 4L60E and moves the front drive shaft out another 2 inches. This could work out to a much easier solution to the front drive shaft clearance problem. I want to get this right and even though I have the expensive Adapter for the D300 TC it might be better in the long run to have a simple straight drive shaft with no clearance problems."
New member, and first post... and I use it to say this: After reading a dozen of so complete rebuild threads over the past few weeks, listening to Randyzzz' advice on transfer case/drive shaft type/clocking/positioning will likely save you a LOT of time, effort, energy (and probably $$$). Every time I'm seen him give an opinion on these things, the OP usually twists, turns, and fights through multiple choices and then ends up doing what Randyzzz suggested in the beginning. I'm just sayin' is all.
Regards,
B²
