Another issue with the PCV system:
You can still purchase the correct 4 cylinder valve, BUT I can not find a grommet to fit it correctly. My solution, and it works:
You can cut the lower extension off with no ill effects. The valve will now fit in the grommet snug, AND it will not bottom out on the internal baffle. Or, just buy a regular 258 PCV valve.
Adjusting the idle on this thing is a 3 part process, and one step is foreign to me, but pretty neat.
First, adjust the vacuum idle on the Sol-Vac, per FSM/under hood decal (1,000 RPM IIRC):
Then adjust the electrical portion of the Sol-Vac:
The neat thing about the electrical portion of this: The power steering pressure hose has a sensor. When you steer the vehicle at idle, the Sol-Vac will kick up the idle to keep from bogging down the 4 cylinder engine. And, it still all works!!!!!!!!! You can turn the steering wheel at idle, watch the Sol-Vac extend and kick up the idle. I did this for a few minutes, I know, I'm a redneck, still thought it was neat!!! The electrical portion will also extend if you have AC when the compressor clutch engages.
Now, the strange part. You have to adjust idle mixture with a dwell meter. So, kick up the idle to 900 RPM IIRC, hook up your dwell meter to the two specified diagnostic ports (7 and 14 IIRC), then adjust idle mixture lean or rich depending on your readings.
Initial set up:
You want it to read around 30, which I achieved:
It is a PIA to access the idle adjustment screw. It faces the valve cover. A short/small screw driver is needed. IIRC, I initially only had this screw out 2.5 turns. According to the dwell meter, I was lean. If i were to guess, I am probably around 4 turns out now.
I also readjusted the timing. I set it before when it was only running on 3 cylinders, not sure if that matters, but it must. It was a bit retarded, took about 6 degrees advance to get it to 12 @1600RPM with vacuum/electrical disconnected. Runs great now.
So, good idle (mostly), starts right up (hot or cold), and accelerates and runs really well. Two issue, more on this in a bit.
Since I had all my crap out, decided to hook up the AMC Feedback tester:
Unfortunately, my 4 cylinder chip is shot:
I checked it with the 6 cylinder chip, but it kept saying "check stepper motor". This makes sense, the 4 cylinder does not have a stepper motor. Anyway, I am 95% confident all the feedback system components are functioning. I still need to change out the O2 sensor, pretty sure running so rich ruined it. I need to scour eBay to see if I can find the 4 cylinder module for the feedback tester.
Two "problems" I have with the engine/carburetor:
(1) The damn throttle shaft will stick sometimes and only allow 20% throttle. It is not any emissions thing/Sol-Vac/linkage issue, the throttle shaft will bind. I can also wiggle it and change the idle. Thank goodness
@Belizeit I have another carburetor to rebuild.
(2) Not really a problem, but "different". On a cold start, push the pedal down once to set choke/shoot some fuel into intake, engine fires right up. On a hot restart I have found it will not just fire right back up. If you pump the gas pedal, even once, it will almost flood out. BUT, if you hold the gas pedal down about 15-20%, then turn the key, it will fire right up. Not sure if any other AMC 4 cylinder owner's have noticed this, or just something peculiar to me/this Jeep/this carburetor???????????
When the throttle shaft does not stick, this thing is actually quite fun to drive. It will spin out on black top, catch 3rd gear in the yard. Good power, responsive acceleration, decent pep. I mentioned earlier, stock tires and 4.10 gears really help in this department. I have not drove it on the interstate yet, I am sure the lower power will be noticeable. As it sits now, with stock tires/4.10 gears, I can shift into overdrive around 35 mph with no issues. I have noticed the OD in the 4 cylinder T5 is not as deep as the 6 cylinder T5, so you do not drop the same amount of RPM.
Anyway, for a stock Jeep, just cruising and light 4-wheeling, I could see a properly operating 4 cylinder as a viable option. Definitely not a 258 or V8, but really not terrible, either.
So I leave it like this for now:
Need to:
1) install new catalytic convertor/front pipe/O2 sensor
2) rebuild/install my other carburetor, and adjust like above
3) sort out the brake parts
4) quit working on JeepAddict stuff and start working on mine
That's it for now!!!!!!!!!!!!!
