- Biloxi
- MS
Small update from last night. I am not doing too much work this week due to my trip this weekend.
Cleaned up, primed, and then painted the parking brake pedal assembly.
Two more rusty parts that I need to clean up and repaint so that I can install the parking brake cables: the triangle piece hangs off of the bottom of the body, the little clip; then secures the cable to the triangle mount.
Picture of all the new door weatherstripping and handles.
And temporarily hung the two doors.
I still have a bunch of adjusting and fitting to do before the doors open and close correctly. I mainly wanted to hang them so that I could start putting all the window/handle/weatherstripping stuff back on them. The tub makes a great door hanging tool
First issue with the doors and body: The doors hit the bolts that secure the Rock Hard cage plates to the dash. I figured this was going to happen. The Rock Hard plates are countersunk for 1/4" bolts which is what you use to mount the plates to the dash if you don't use the pieces that tie the plates to the floor. Since I used the extra pieces to tie the plates to the floor, I used the supplied 5/16" bolts. Should be an easy enough fix to get a counter sinking bit and enlarge the holes in the plates, I hope.
Picture of the bolts in the door jamb area. I already removed one of the bolts in this picture.
Close up picture showing how the head of the bolt sticks out. Once I countersink the holes in the plate to the correct size the bolt heads will sit flush, and no more problems, I hope.
My sand blaster blasted the rims already this morning, should prime them late today or early tomorrow, should be able to pick them up tomorrow afternoon. Then, back to the painter.
That's it for now.
That's it for now.
I need the piece that goes on the PASSENGER SIDE
