After heading west into the setting sun, or heading east into the rising sun, one too many times, I finally installed my sun visors. They will work with the in cab roll cage, but you do have to kind of bend them/force them down. If you have perfect condition sun visors, you might not want to do this.
I have two nagging leaks that I need to fix. The first leak is from my new radiator. It is leaking coolant out of the top tank seam. It only leaks after you shut the engine down. Since the radiator has a warranty on it, I am going to pull it out and replace it. It is fairly simple to remove my radiator, one overflow hose, four bolts, and two hose clamps and it is out. This is an easy leak to fix.
My second leak is a bigger pain in the butt to fix:
That's right, the power steering box. This is the one component that I did not change out when I completely rebuilt this Scrambler. I guess it serves me right. If you have never changed out a CJ steering box, get ready for a world of fun. My change out was also complicated by the three other factors:
1) I have a winch that covers up the top mounting bolts ( a winch that I promptly dropped on the end of my finger, smashing it so hard it cut the end of it off almost all the way off) which I had to remove to gain access to the bolts.
2) A steering box brace, which ties into the passenger side shackle hanger bolts, which has to be removed, too.
3) One of the factory nut insert in the driver side frame that hold the steering box in place is missing from my frame. I dropped a bolt down through this hole to secure the box. But, in order to remove this mounting point, I have to slip a wrench inside the frame to keep the bolt head from spinning, In order to do that, I have to remove the winch mounting plate off the frame rail.
After securing the frame on jack stands, removing the driver side tire, holding up the unsprung weight of the axle with two floor jack (Remember, you have to remove the driver side shackle hanger bolts to remove the steering box. If you leave the weight on the suspension, well, lets just say bad things could happen.), a bunch of bleeding, followed by cursing when power steering fluid runs into an open cut, and about 6 hours later, my new steering box was installed.
The new steering box works great. It does not leak, which is priority number one. My old steering box did not feel loose at center, but this one feels tighter. So, my already tight steering is even tighter.
That's it for now.
