Andy purchased a new MSD Po Billet distributor for his Jeep, so that is what I am going to install. I am going to use the distributor to control the timing. This distributor is very user tuner friendly. I am going to match the new distributor advance curve to a OEM 1982 non-computer controlled timing curve.
From the '82 FSM, I am using information for 49 state CJ's (NO feedback system):
Make sure you read the fine print!!!
So, set the initial timing to 8 degrees +/- 1 degree at idle speed.
On the OEM distributor, the mechanical advance comes on fast, and only gives you around 12 degrees additional advance at 2000 RPM:
The vacuum advance really ups the total advance, close to 26 degrees at 18" vacuum:
On both of these advance charts, kind of confusing. I believe they are taking into consideration your "initial" timing adjustment of 8 degrees. If you start the engine, set the timing to 8, disconnect and plug the vacuum advance, and increase the RPM to the specified RPM markers, you should get the mechanical advance readings IF the mechanical advance is functioning properly. I have done this in the past and hit all the markers, if a bit closer to the high end of the allowable graph space. The FSM also mentions that "total" advance (initial+mechanical+vacuum) will be anywhere from 32 to 39 degrees. This makes sense if you look at the two charts. Add the 12 degree maximum mechanical advance with the 26 degree total vacuum advance (measured with the engine off idle slightly, but not enough to get the mechanical advance into play) you get 38 degrees total advance.
Compared to how the MSD distributor is set up from the factory, the biggest difference is how fast the 258 mechanical advance comes on fast and hits it's 12 degree maximum at 1800 RPM:
If you add the 8 degree initial advance to the totals below, you will be anywhere from 38 to 45 degrees total advance.
The MSD has way more mechanical advance, but it does not come on until around 3-4000 RPM. So, with the MSD I can get way more mechanical advance, but only 12 degrees of added vacuum advance.
With the 21 degree stop bushing, and 12 degrees added vacuum advance, and initial 8 degree timing, I will have a total of 41 degrees timing advance. A hair above what I need, maybe. But, I can install the 19 degree (purple) stop bushing to limit the total mechanical advance:
I forgot to take a picture, but I will also change out the installed stiff advance screws to a lighter set. This will get the mechanical advance to be all in at a lower RPM range, better matching the stock 258 advance curve.
I am still thinking, but pretty sure I will swap out the 21 degree advance stop for a 19 degree stop, and install lighter springs (that are included). The instructions show 24 potential curves (different advance stop bushing and spring combination on 6 charts). Pretty sure I will go with the "E" chart, purple stop bushing to start. If no pinging, I can always go a bit lighter on the springs, and/or reinstall the smaller stop bushing.
This is a very nice/customizable distributor, way more then what I am used to. So, I will take advantage of its tuning capabilities. In the future, the vacuum advance AND the mechanical advance can be locked out completely, and the Sniper can control the timing, if desired.
