- Biloxi
- MS
Some easy work, some slightly PIA work.
Received and installed the "intake manifold heater/choke" relay":
I also installed, about 95% complete with, the rear fuel pump module harness. Two wires run from under the hood to the fuel tank:
1) the fuel pump power wire from the Holley Sniper wiring harness relay
2) another "has to be battery negative post" ground wire from the fuel pump harness up to the battery
I ran these two wires together, down the firewall, and then along the OEM fuel supply line, down the passenger side frame rail, across the forward fuel tank crossmember, over to the driver side of the fuel tank where the fuel pump module harness hangs out:
I just need to finish some wire loom on the end to be 100% finished with this circuit. I hope to finish up my remaining wiring work this weekend (oil pressure gauge, secondary temperature gauge, aftermarket tachometer). After that, build an exhaust system, clean/install an OEM air cleaner, transfer case shifter, and some other odds and ends.
IF everything goes right, MAYBE try to fire this thing up next weekend
That's it for now
That's it for now
