Dang near killed myself!!!
Marine-OpLaw
'ANTIQUATED' PackRat
Fredericksburg
VA
Holy crap! :o Right now I'm praising the Lord for sparing my family's lives despite my incredible ignorance! He IS merciful indeed!
(Expect numerous errata... my heart is still thumping like a jackhammer after realizing the depth of my lame inattentiveness.)
If ya'll will recall, about a month ago I installed an RE 4 1/2" lift on my Scrambler... just prior to attending Camp Jeep. During or immediately thereafter, I noticed my right front spring hanger leaning outboard. W/o much thought, I figured the bolts needed retightening, so that I did - to the point of squeezing the daylights outa the poly bushings. Still at an angle, but I was too busy to investigate further... Kept driving daily, to include highspeed Interstate runs... w/ my kids no less.
Finally, in the last few days, I noticed the lean was really getting bad. So, this morning, after aborting a HS run 90mi away (for other reasons), I decided to go out and take some digital pix to send to RE w/ a rant asking them to replace the obviously faulty :o spring, and related parts. (Still blind & clueless as to my situation.)
Only once ready to take my pix did I finally see the real (as in REAL OBVIOUS... had I been paying attention) source of the leaning shackle:
Completely severed/seperated spring hanger... barely held in place by the edge of bumper frame bracket. Dang! How close... and how many times, did I come to death... and killing my kids?! I CANNOT BELIEVE I WAS SO DA** IGNORANT as to not notice that thing! [Not even Homer S. is THIS stupid!)
[Heart still thumping as hard as it was before... Gonna take a spell to get over this...)
Sooooo..... how'd I likely break that thing? (It broke in front of the two bolts holding it to frame @ the hole where the frame 'rivet' nests in.) Did both sides likely break/crack at the same time, or did they both likely break at different times/seperately? I cannot think of anything we did on the Camp Jeep trails that would've busted a spring hanger. Do these things break often in road driving &/or light trail use?
Replacement: New? or is a used junk yard pull okay to use? If new, any particular one I should go with? Replace both or just the busted one?
Should I replace the poly shackle bushings I squeezed the p**p out of by overtightening?
I suppose this is why my steering seemed so inconsistent... relatively tight, 'loose-as-a-goose', back tighter, loose.... [repeat].... Duh...... (I thought it was just the effect of the lift, larger tires, and lockers...) :(
Still cannot believe I survived this w/o tragedy..... and/or a destroyed Scrambler.
BTW Eric & John, why didn't you catch this (for me) last Friday?!:p :D
I'm here to tell ya, there IS a God and He is MERCIFUL to His foolish children. I count my blessings and my cup overflows... Praise Him for His goodness!
Wow that's some scary stuff right there!
Yep God is good indeed.
To fix your problem I'd suggest welding the perches on there, also inspect the frame for Rust etc, it's possible the bolts pulled right through some rust places on the frame.
When I bought my Scrambler my rear spring hangars were coming loose, the bolts were seized so I couldn't tighten them down. I had a local shop weld them inplace and they have been fine ever since. Like 7-8 years of abuse.
Good luck!
Mark
Problem is he sheared the shackle hanger.
WP Warrior makes heavy duty replacements $41.95 in the JC Whitney catalog (reading it right now). They're reinforced in that area. I put a pair of rear ones on my Scrambler when I outboarded my springs so I could run YJ leaves. They make them for the narrower CJ front springs too.
You can get factory replacement shackle hangers for $10-15 each.
I had a bolt come out of one of my rear shackles once. It's an eerie feeling when you feel the rear end 'float' around.
D%MN JERRY, I guess we have to do safty inspections for you now!!:eek: :eek: !!
I've got my complete original set in a box on the shelf in the garage, they're your's if you want them. I think they're in good shape. I can't say why your's went south on you, they could have been cracked or fatigued when that thing was wrecked before you got it. Or maybe it was that cold ride home or wife's revenge for coming home late last week, you could tell her, "at least she's not married to the governor of NJ, things could be worse."
I replaced all of mine with the Slickrock ones from JKS, they were part of my Christmas last year.
I second the Slickrock ones.
I have a set that are waiting to go with my OME kit that I got from JKS too. They are real beef.
The frame would fail before them.
Carl
Dang Jerry,
I'm glad you and yours are alright. That could of been terrible. Being watched over indeed.
Truck
If mine went, I'd opt for the HD replacements too Jerry.
If you recall, I didn't see your ride until it was dark AND it was pointed the wrong way for me to see it, even when I had the XJ's headlights on it to check it out.
You're blessed man, that's for sure. If all the great deals on Jeep stuff, great kids and wife weren't proof enough already! :D
THanks guys...
I appreciate all the kind words... and especially the fact that no one said (outwardly anyhow) "darn!"
In addition to looking over the JKS and JCW HD spring hangers, I'm also looking at the ones made by Full Traction Suspension. Ol' Moses Ludel recommends them in his latest CJ Rebuider's Manual. They have an additional length of plate out front where they bolt on using the frame/bumper bolt. But have to see what their price tag is first. Just about all the real beefy looking upgrades are pricey, but then again given my marginal ability to see problems in that area, MAYBE I NEED something that definitely won't break in my lifetime.... after all - my Alzheimers/blindness/inattention isn't going to be getting any better:rolleyes: :eek: :D
John, THanks for the offer... I might take you up on your offer, if I get down your way before I get it fixed (doubtful).
Typing this from Sheraton Hotel office computer ini Harrisburg, PA - taking the family to Hershey Park tomorrow. Hopefully, my computer will be 'fixed' by the time we get back. Mailing Oak Ridge pkg appl. tomorrow morning.
Well the factory front hangers are susceptible to breaking based on their design. The large hole for the rivet is a weak point. I personally believe that there was nothing wrong with your hanger until you over-tightened the shackle bolts. When you tightened the shackle bolts down you effectively made the shackle rigid. Every bump and dip worked the hanger up and down and back and forth. After enough cycles it decided to break. I personally run Slickrock hangers on all my CJs. I also leave my shackle bolts fairly loose. I have double nutted all of them with steel locknuts. Loose shackles allow the suspension to flex without binding. If I were you, I would install some stronger than stock hangers and reuse your existing shackles/bushings. If you bent the shackles by overtightening them, then you need to open them up again. Tighten them down until the poly just makes contact with the shackle. Overtight shackles will make your CJ buck like an old wagon. If the shackles appear to be tilted in or out, then you need to loosen the U-bolts at your springs and see if you can coax the leaf packs right or left as needed. Tighten the u-bolts when the shackles are vertical. Hope this helps.
Later,
Tom
Right now I'm praising the Lord!
He is and always watching over us bro!.......Don't be so hard on yourself..........chalk it up as a learning experience.......after every trail ride before i unload it off the trailer.....I wash it and then crawl around under it looking and shaking things..........you will be surprised on how much stuff will work loose just driving it on the road much less on the trails..............Good Luck and crawl around under your rig once in a while or take it to the shop and put it on a lift and just check it out once in a while-JC
agreeed
I echo everyone else about slickrock hangers. I've got them all the way around on my CJ. I have seen the stock ones crack/split right where you mentioned. Just like John, I've got my stock set you are welcome to. I keep them in my storage/tool box as well as the stock spring plates to keep on the trail for spares and repairs. You are welcome to these if you need some to get you through until you buy slickrocks or even if you do want to use stock replacements.
And also, just keep it in perspective of thankfulness and chalk it up as learning. I don't know how many times I have done something similiar and after I discover the mistake I made, I stand there and do the same thing. I will end up shuddering at the thought of what could have happened but didn't. But, just use it as learning of reminder checklist for the future.
matt
Another vote for slick-rock... Had them all the way around on my 7, will have them all the way around in my 8. They're beefy, and I've SEEN what happens when the factory hangers let go and it's NOT pretty.
Glad you and your family are OK!!!
