Input needed
MrBeep
CJ-8 Vendor Supporter
Member
CJ-8.com Vendor
Dillsboro
IN
Just a quick poll. :confused: Starting a 7day build of a glass Scrambler. I would like some input on the engine/trans set up. The NT axles are a stock 30 with 6 bolt hubs, 4.10s and ARB locker and the rear is a Corp. 20 with Superior axles, 4.10s and ARB locker. 4" Skyjacker lift and 33s.
Intended use is 85% road, 14% trail and 1% show.
Engines Availible:
A AMC 258 with Mopar Fuel injection, 15K miles on rebuild
B AMC Performance 360 (60 over bore) pushing 375 horse New
C AMC Stock 304 with 24K original miles
D SBC Fresh 355
E BBC Fresh 409 Mild performance
F Caddy 501 Stock with 62K miles
Transmisions Availible:
A AMC 999 New
B AMC AX-15 45K miles
C AMC T-176 Fresh
D NV 4500 for Chevy New on the crate
E Turbo 400 / DANA 20 for Chevy Fresh
F Turbo 400 / DANA 20 For Caddy Fresh "TCI"
Too many choices! :banghead:
Thanks in advance for your input.
Not to Eric: You don't REALLY need pictures of ALL of them do you? How about just the winner?
:wave:
I'm partial to the 258 with MPI. Axle setup sounds practically idenitical to mine except for the locker choice. The 258 has good torque for the low end and I can push 90 on the interstate unless I hit a headwind.
I run a T5, so I can't say I'm experienced with your tranny choices. I'd probably lean towards the NV4500 myself if it's not too difficult to mate up. I like a shifter in my hand so will avoid the auto's in my Jeep.
$0.02 ;)
For me - id go the NV4500 (advance adaptors bellhousing) & AMC 360.
But if its 85% road, this might be too aggressive...but I like it :thumbsup:
258, with nv4500. with all that road driving, if you put a big V8 in.... you wont be driving it on the road much. NV4500, nice strong manual, with overdrive. if you get the one with the real bull low, prefect for off road, too!!
I have a fuel injected 258 and a ford T-18. great for street. wish i had an overdrive. but with the 6.35:1 first gear, it kicks *** on the rocks too!!!
First thought was D and D. Power to pass and good low range. But...I'm guessing the only EFI choice is A....in which case I'd go with A and B. The AX's shift soooooo nice...especially with a short throw shifter. A street driven Jeep's dream.
I'd vote for the injected 258, just seems right with the axles you're using. AX-15 seems logical too.
You know you are going to end up with some kind of V8 in there, racer boy.:popcorn:
IMHO, I would save the NV4500 for a V8. It's overkill for a six.
Do you have a 208 laying around to use with the AMC 8?
Time is running short to go searching for adapters.
What are your plans for the Atlas?
Go with the 258 with mopar fuel injection, and 999. This should be a trouble free set up. I'd like to see you make all the trails this year.
Don
I do have a couple of 208s along with some 300s in the shop. leaning toward 258 & AX-15...... BUT MAN that 501 caddy would be sweet in there! :banghead: :banghead: :banghead:
The Atlas IV is going in the TJ-8-10a along with the Turbo 400 and either the ZZ-7 or the 355. :confused:
:wave:
First choice is D&D. Second choice is A&B.
