Joe's 1982 Scrambler Restoration Thread (Retitled From: Bringing The Scrambler Home)
Joe, it looks good. Great siderails. I vote keep the hood on the Jeep. It's a classic!!! And yes, the white looks good.
Thanks. A number of people have mentioned the white and blue combination. Originally, the scrambler came with a white hard top, white bumper, and white wheels. I've added the sidesteps at the request of my wife but I'm not sure if I will keep them white or not. I think the factory always painted them body color.
As far as the hood goes; it will either get fixed or replaced... I think the Scrambler would not look so sharp with a mangled hood and fresh paint :D
Joe
I'd do the steps in black.. matches your other trim (ie: mirrors) and helps "hide" them as a feature along with the frame/undercarriage.
Any intent to paint the spare white? I think it would look better mounted up there matching, and you wouldn't have a mismatch if you do a five tire rotation. .02
Also.. the Krylon Fusion spray paint works wonders on the plastic fender trim pieces... made the set on my CJ7 look practically new, took half a day to remove/prep/paint...
I also had good luck using rattle can of plasti-dip to coat all the hood bumperetes and latches, gives them a nice rubber texture and improved their appearance alot.. something to think about when you do swap the hood..
The spare is actually painted white on the front surface, but the back is whatever color the factory left it. I checked all 5 of my wheels, all of which are factory wheels that have never been repainted, and all of them are white on the outside and black on the inside. I'm guessing all wheels came from the factory black and then they painted the front face of wheels white as necessary.
As far as the steps go... I'm not sure if I'll leave them white or paint them the factory blue color. I like the way they look white, but I'm trying to restore the Jeep to factory condition and I believe all side steps were body color (but I could be wrong on this... I've only seen a small handful of pictures)
Joe
Joe
Joe, the Jeep looks great! I'm only going by what I've seen but it seems like body colored side steps were an option and black was standard. Like I said, I'm not totally sure on that but I've seen "unrestored" CJ's with both.
Those wood rails look great!! Good job on them. :thumbsup: Whole build is looking great infact. Is that just a warn winch mount or a custom one for the 8274?
I removed the old dented fenders off the Scrambler today and installed a pair of fenders I purchased from one of the members on virtualjeepclub.com. Once I find a replacement hood, I'll start on the body work and then off it goes to the painter.
Here are a few pictures:
Joe, it looks great. I presume that you are going original color? Great shade.
I have a question based on the 2nd pic: the steering shaft on mine rubbed a pinhole in the lower radiator hose. Do you have something on yours to prevent it from having direct contact or is there some distance between the hose and the shaft (more correctly the threaded 'screws' on the shaft) on the factory setup? (There is something blue and silver in the picture that I noticed).
When is it going to body and paint?
What you are seeing is just the radiator hose part number tag and the silver clamp
My hose is clear of any contact with moving parts.
Paint is probably a year or two off.
Looks like you found an excellent set of used fenders, color almost matches, too:cheers::cheers:
Finally... a new hood.
I finally found a replacement hood that was the correct year for my Scrambler.
With the new hood and fenders, it's ready for body and paint work... someday... :)
Wish I lived in that cul de sac in Mesa. Lookin good Joe. Nice work.
Joe,
for a short term solution.. or maybe long term.. on the tie downs and hood latches for my CJ7 I used a spray can of "plasti-dip" rubberized spray paint.. I scuffed up the surface, secured them to a piece of cardboard, and gave them 3-4 coats.. leaves a pretty durable and rubberized soft-touch texture to each.. I was happy enough with it
unless you're going with chrome, then disregard!!
looking good!
Joe (and/or the forum members)
Joe mentions he finally found the correct hood for his Scrambler.
Question: How are they different? I though they were all the same, even onto the CJ-7 versions?
Please reply, as I am heading to actually buy a new hood today, and don't want to make a critical mistake? :(
Thanks for your replies!
Anyone? What's the difference in ANY CJ-8 hood?
Thanks a million......I'm just wondering because I need to buy my new hood ASAP.
Thanks!
Hoods
As far as I know, All hoods, CJ-5,6,7,or 8 are the same 1972 through 1986. Prior to 1972, they were shorter and after 1986 they went with the "square" YJ" style.:thumbsup:
:wave:
Maybe Joe was looking for the approx. 1980 and later hood without the recess for cables to lay through. My early 1979 had the notched hood where it meets the top of the flat fender. My 1980 has the hood like Joe's 1981.
my 1983 hood does not have the windsheild tie-downs and bump stop/loops for the windsheild support when it's folded forward.. my CJ7 had them.. is this the 7 vs 8 difference?
