- Mount Pleasant
- SC
Would have been a perfect opportunity to give the inner fenders a good scrub and maybe even reach in there and cut and polish? One (two) of those areas which, when clean, can really make the engine bay sparkle, especially with all your original enginey stuff in there. What's the go with that thing beside the brake booster? Is that to do with your park brake?
You read my mind, Gazzo! Hitting those inner fenders with degreaser today and will clean them up. The lower inside of the grille has a bit of rust. I'm going to repair that area (hopefully today if the Interior Minister doesn't have a fit) also before buttoning it all back up. The radiator could use a little paint love as well.
Are you talking about the proportioning valve next to the booster? This is an aftermarket booster the PO put on. Not real wild about it as it interfered with the stock air cleaner and the mechanic that did the upgrade had to modify the cleaner housing. Let me know if that's what you're asking about.
I'm not done sniffing this out yet.
