jscherb
- Elmira
- NY
twmattox said:As usual, the stuff you are working on looks incredible. Just a couple thoughts...
That ebay rig looked like a small Jeep attached to a trailer. The problem I see (even with the Brute) is that the rear cab corners of the front don't flow with the front corners of the bed. It makes them visually look separate. In the drawings you did, you show square corners...but (for instance) in the ebay ad the corners were rounded. I guess I am saying it looks best for the intersecting corners to match (like your drawing).
Also, the other thing that would stand out to me is the use of black wheel guards (mud guards) on the front and the lack of them on the rear. Again, a small thing that would promote a more unified look in the rig.
Please don't mis-read these comments. I think what you are doing is phenomenal...and envious.
Don't worry about me mis-reading... even if you tell me it is crap, as long as you explain what you think I've done wrong, it's fine... I really appreciate the input.
I'm not sure what you mean about square corners - are you saying the model doesn't match the drawing? Can you explain a little more?
I have been considering putting the flares on the rear fenders also, but I've never seen stepside fenders with flares. I was thinking that would look more strange than flares on the front and not on the back. Still mulling it...
The only additional input I have with the design is that the bed sides look a little high relative to the cab side height. Overall, it looks great, and your fabwork with the model is very high-quality, too. Keep the updates coming.
