- Biloxi
- MS
Small update.
Dropped the exhaust back out, getting the blown up cat cut out, old O2 bung welded up, new O2 bung welded in.
"X", hopefully, marks the correct spot for the O2 sensor.
This is the O2 sensor that was installed when the cat caught on fire. The plugged cat/broke O2 sensor was causing the engine to run rich. The plugged cat also caused exhaust to back back up into the engine, it was coming out of the PCV breather out the valve cover!!
Started on the wiring.
Cleaned up the wires from the alternator to the starter/positive lug.
Ran the two constant hots/starter solenoid wire up the firewall. I also cleaned up the fuel pump/sensor wires. I might go back and put all of this in a single piece of plastic, but it might not look much better.
Ran the two hots/starter solenoid wire over to the diver side. The rest of the Jeep chassis harness wires need to go with this bunch, too.
I need to run/add the following wires to the "cross the firewall bundle":
ignition hot to TBI harness wire
oil gauge sender
reverse light stuff
heater blower motor
4wd indicator light
I also need to make a "diver side to front of engine on side of intake harness" to contain:
the alternator ignition feed, with a resistor
temp gauge sender wire
I also need to make/run the following harness to the transmission:
TCC harness
VSS harness
And I need to hook up the following stuff inside the jeep:
oil pressure gauge
engine temp gauge
transmission temp gauge
tach (maybe)
install computer
mount OBD port
check engine light
I have what's left of this Jeep's original underhood wiring, plus a complete Chevy truck TBI harness. I should be able to splice some of these wires to what I need to do, so everything matches.
I am going to "eat my broccoli" first, and complete the wiring, before I do any other "easier/funner" work.
That's it for now.
oil gauge sender
reverse light stuff
heater blower motor
4wd indicator light
TCC harness
VSS harness
oil pressure gauge
engine temp gauge
tach (maybe)
install computer
mount OBD port
check engine light
That's it for now.
