- Biloxi
- MS
I installed the heater flap next, it will only go in one way. Secure the cable with the little push clip washer thing:
I installed the heater core next.
I test fit the metal back panel next, and I had to slightly "tweak" one of the heater core outlet pipes to get it to all line up. Be careful with any "tweaks", could cause a "leak". I crack myself up.
Some people install foam around the heater core. I did not. In the above pictures, this core fits tight to the box, I can't see how adding any foam around it would help? Some cores need a piece of foam on the top or bottom to fit tight, this core fits tight as is.
Also, check your heater core to back panel attaching screws BEFORE installing the back panel. On some cores, if you use a screw that is too long, the screw tip can make contact with the core and cause a leak. On this core, it would appear that the upper tank is not directly underneath the two holes in the heater core attaching bracket. I'll take a picture and post it later, BUT the core I removed is not like this, and if the attaching screws are too long, they will make contact with/through the heater core tank!!!!!!!!!!!!
I decided to use this stuff to seal the plastic portion of the heater box to the metal back panel:
It is a sticky, Play-Doh, type stuff. I used this stuff to stick the wax paper to the metal door skins on my red Scrambler, seems to work well. Also, no where near as messy as RTV or other goop. When I disassembled this heater box, it had remnants of some similar substance on it, maybe the factory used something similar, who knows?
That's it for now!!
That's it for now!!
