Figured out a simple solution to the age old problem of the receiver that you use to hold the halftop to the bulkhead. If yours are like mine were, they have been stripped after 40 or so years of use.
Initially used some AVK ( insert nuts) but you have to have the ones with a long enough grip range. I only had 3 left from my stock from my job I retired from 4 years ago, so I went is search of something else.
This works great. All you need is a 15/32" bit, a 1/4-20 rivet nut tool and 4 of these jack nuts from your local Hillman selection at most Ace or True Value store. Drill the hole out, install the jack nut and you are good to go. You may need to by a longer 1/4-20 bolt to use to draw the jack nut tight as the Dorman bolt was a little short for me.
