jeffs396
mini Scrambler
- NE
- OH
This project just amazes me, as much or more than 80% of the actual Jeep projects I have seen.![]()
Wow...looks great!
Thanks! The +++ comments mean alot!
The first test frame is cast! Once I have it back from the caster, I'll give it a once over & fit check against the body, then have him cast as many as the mold will allow(usually 30-40 copies). Then I'll finish the body & send it off to be done!
and just finishing up detail work on the tub, hardtop, & bulkhead. I've got two questions for those of you wanting a kit...was there just one upholstery pattern during the production run of Scramblers??? Also, how many actually have your OEM seats still in place, or have they been replaced with aftermarket seats? If you don't already have your CJ-7 donor kit, here's what the seats & door panels look like...sure won't work in a Scrambler! The blue seat comes close to the original style/pattern, but would need some work to be correct. The black seat & door panel are from a YJ kit and would also need work to be correct.
so I can do a test fit with tub to be sure everything is just so...I'll post a pic of the finished tub before I send it away!
support at the bottom will be removed upon assembly...
