- Biloxi
- MS
Installed transfer case shifter, transfer case vent line, and the 4wd/reverse light wiring harness.
Ran/hooked up the transfer case, front axle, and rear axle vent lines.
Since I got tired of dropping parts through the huge hole in the floor board, i installed the trans cover, transmission shifter, boot, and knobs. The threaded portion of the transfercase shifter was snapped off, so I had to drill/tap/install a stud. I was able to reuse the original shifter knobs, and surprisingly, the original boot is in excellent shape.
Installed glove box door and the original speedometer.
Installed u-joints in the driveshafts, installed driveshafts.
