My Big Red Scrambler
Your fender flares look really really nice! What type of speedo is that? Is there a digital readout in the middle? Cool project excellent work
Should have mentioned this before, notice the bearing on the end of the steering column. Super nice stuff, and an awesome upgrade. Wolff Engineering
View attachment 69325View attachment 69326
I need to look into that, the lower bearing on my red Scramblers column is a bit loose in the housing, i.e. the plastic bearing retainer to column fit. I was going to put a hose clamp around it to tighten it up, this looks better :cheers:
Yes you do, especially with all the driving you do across the country!
Hose clamp, hmm :sneaky: really...
Thanks for posting that. I'm going to look into that bearing as well. I bought a new one last year (I think crown) and it was just as loose as my worn out one.
I’m going to use it to vent the fuel tank
I'd have to check a little more, but I'm not sure its design is compatible with the way the 5.3 vents? Unless you've figured out a way?
CJ and YJ canisters have the purge line to the engine, but it's controlled by a vacuum signal. With 5.3s the signal is from the computer so by default you'd have to have a way to keep the canister open?
