Yep , getting the dash in is a nice chunk of the puzzle.Very nice. That’s such a huge difference to have in and done
Your fender flares look really really nice! What type of speedo is that? Is there a digital readout in the middle? Cool project excellent work
Should have mentioned this before, notice the bearing on the end of the steering column. Super nice stuff, and an awesome upgrade. Wolff Engineering
View attachment 69325View attachment 69326
I need to look into that, the lower bearing on my red Scramblers column is a bit loose in the housing, i.e. the plastic bearing retainer to column fit. I was going to put a hose clamp around it to tighten it up, this looks better
Yes you do, especially with all the driving you do across the country!
Hose clamp, hmm really...
I'd have to check a little more, but I'm not sure its design is compatible with the way the 5.3 vents? Unless you've figured out a way?I’m going to use it to vent the fuel tank
