- Bedford
- NH
Yamaha CD player wouldn’t open up. Found the belt to be broken that opens the CD tray. Fixed it with a rubber band. I’ll fix it in 25 more years.
Got to have my Widespread Panic
One arm Steve has been responsible for a lot!
That was so fun when my boys were young. Used to put the "axles" in the drill and take off any burrs and polish a little. Most important was to put a plate on the bottom with 2 screws and be able to add weight under it for the maximum allowed weight. Graphite on the axles and make sure all 4 wheels sit on the ground and are lined up. The more times the car goes from side to side against the guide the more drag on the time. Areodynamics helps but an overweight block can beat a lighter car that's done well. Check the wheels for mold lines and remove any you find. Good hands-on learning expierence for boys. That's my 2 cents.Well, it’s that time of the year.
