I wondered about a "break in period", even though it seems odd. I only have maybe 1500 miles max on this set of tires. I'll keep them a bit longer and see if they get betterI have the same tires on my blue Scrambler. They are very smooth going down the road. BUT, I had a hell of a time getting them to balance in the first 3 ish thousand miles. I would re balance them once every 700-1000 miles. The road force AND balance was way off every time. It's like they had to "break in" a bit. It was very annoying at first. But after a few thousand miles they drove very smooth and I haven't had to re balance them in a long time. I'll "check" the balance once a year like I do all my stuff, but haven't had to change anything so basically the problem went away.
If they don't get better I may have to take you up on that offerDon’t toss them. I can probably maybe get my buddy to balance yours sometime maybe to see if there is a problem. If all else fails
It’s one of those, on the down low thingsIf they don't get better I may have to take you up on that offer![]()
Ya, that's f'g crazy. Very frustrating.Its funny, I have been to four separate shops, and each one says the previous shop did not balance them correctly. I have never had this much problem balancing tires before in my life. Find it hard to believe that all four shops incorrectly balanced the tires, but who knows![]()
Do you have paperwork showing 4 shops tried to balance them? If so, I would contact BFG and send them that as evidence there is an issue. I suspect a broken belt in a tire that can’t be easily detected.Its funny, I have been to four separate shops, and each one says the previous shop did not balance them correctly. I have never had this much problem balancing tires before in my life. Find it hard to believe that all four shops incorrectly balanced the tires, but who knows![]()
This is a good thought. However whenever I came across a broken belt in the tire it would present itself doing a road force balance. Normally to correct road force you pop both beads on the tire, then rotate the tire on the rim. Re inflate and re road force balance it. The road force will change, sometimes better and other times worse. You sometimes have to rotate the tire on the rim a few times before you get it in spec. A broken belt in the tire won't allow you to do this. It will show a terrible road force balance no matter what you do.Do you have paperwork showing 4 shops tried to balance them? If so, I would contact BFG and send them that as evidence there is an issue. I suspect a broken belt in a tire that can’t be easily detected.
Yep, have all the paperworkDo you have paperwork showing 4 shops tried to balance them? If so, I would contact BFG and send them that as evidence there is an issue. I suspect a broken belt in a tire that can’t be easily detected.
This. I spent many years balancing tires, I was management but always got called to balance the difficult stuff. I was BFG certified for many years. Sometimes you have to break down and remount 180 out to get a smooth ride. Also, if you look at the weight placement and there are weights in more than one spot per side, it isn’t balanced right. I also believe that the new “low speed” balancers don’t do as good a job on truck tires as the older high speed balancers. Lastly, using chalk while on the balancer can find a lot of issues. I would hold the chalk so it would barely touch the sidewall or tread- you can see if the tire is out of round by reading the chalk marks.This is a good thought. However whenever I came across a broken belt in the tire it would present itself doing a road force balance. Normally to correct road force you pop both beads on the tire, then rotate the tire on the rim. Re inflate and re road force balance it. The road force will change, sometimes better and other times worse. You sometimes have to rotate the tire on the rim a few times before you get it in spec. A broken belt in the tire won't allow you to do this. It will show a terrible road force balance no matter what you do.
You got to what I was thinking while reading this post the noise is in front of the transmission, not the transmission or back, throw out bearing is what pop into my head while reading.Nope, noise still there intermittently once hot
Drove it about 200 miles today. After about 2 hours, in traffic/lots of red lights, heard it briefly once. On the way back home, again in lots of traffic/red lights, made the noise a few times.
It shifts fine, no grinding/knocking/kicking out of gear. Just makes noise sometimes. Only at low speeds shifting into 2 or 1, or from neutral to 1. No vibrations or shifting issues, clutch does not slip or pulsate.
When I got back home, put the transfer case in 0neutral. With engine running, clutch out, you can shift up and down 1-4 no problems (reverse and 5th need the clutch pushed down). So, pretty sure all the synchronizers are fine. No strange sounds with clutch out and transmission in gear or neutral., countershaft and bearings sound fine.
So, with Dana 300 in neutral still, pushed the clutch down, held engine at around 1500 RPM, I get the noise. Does not matter if the transmission is in neutral, in gear, or moving between gears. With clutch pushed in, RPM's up the noise is there.
So, starting to think the throw out bearing is the culprit. Makes sense, intermittent, happens when shifting gears (clutch down), sounds like a bearing.
So, sometime in the near future I will be pulling this T5 back out to investigate/potentially replace a barely used release bearing![]()
Looking at my notes on my red Scrambler, I first used a N1444, then a few years later a N144SA, both from NAPA. No problem with the SKF N144SASo, sometime in the near future I will be pulling this T5 back out to investigate/potentially replace a barely used release bearing
Welcome to my world...........Get the TOB from NAPA and be done with it. Best of luck.
Unfortunately, looks like I purchased a LUK clutch kit and LUK flywheel for this one from RockAuto for some reason. That is OK, but for some reason I purchased and installed a cheap National 614115 release bearing, according to my receipts/notes from back in the 1st quarter of 2017. No idea why I used the cheap TOB???He probably got it there. View attachment 107583
Yep, great minds think alikeYou got to what I was thinking while reading this post the noise is in front of the transmission, not the transmission or back, throw out bearing is what pop into my head while reading.
