Torqueflite 999 rebuild
Possibly a 6207 bearing 35mm x 72 mm x 17 mm? - check the size in metric units.
Very close, 31.25 mm d, 72 mm D, 17mm B.
Only concern is the 3.75 mm tolerance on the shaft. I might have to use that bearing and machine a bushing to close the gap.
The shaft measures 31.35 mm, giving a 0.1 mm tolerance, or 0.05 mm each side. This is a nice slip fit.
If you are unsure of the part number or alternate bearings I would suggest checking with CJ7Pilot (member here).
I don't remember his qualifications but he in a great resource for everything to do with bearings.
@CJ7Pilot any suggestions? I could use all the help I can get.
For now, I think I will scavenge one from a spare transmission in the barn. But, I will want to replace it when (if) I find one.
I am also soaking the original one in the parts washer. Just replaced the mineral spirits yesterday. Forgot how clear it was supposed to be. Old fluid was a dark brown from all the oil and silt in it. If I had dropped the bearing in the old fluid, you would need to feel around to find it.
Pulled the tailhousing adapter off another transmission, and out fell (literally fell out) the bearing and 3 shims. I don’t recall seeing shims mentioned in any reference book I have, but then again, most only discuss the 2wd version.
This bearing is marked MRC 207SG9 USA
Only bearing that comes up in a search is the 207S which is a 6207 with an inside diameter of 35 mm. Still stumped on where to get a replacement, but the build can continue with the donor bearing.
They must have used a custom bearing, it should be possible to machine a bushing, just have to design it to hold the bearing in position on the forward face
Picked up one more resource. From all others I have looked at, none call for shims at the output shaft bearing in the adapter housing. Even my ‘82 CJ FSM and the ‘89 Jeep FSM do not mention shims at this bearing.
It looks like you're not the first one to go down this road: https://www.cj-8.com/threads/chrysler-a999-tf999-output-shaft-bearing-replacement.45891/
Transmission bearings can be a bear to locate. Most modern transmissions have a special input bearing, or output bearing, with the rest of the bearings being standard sizes. The idea is that you can only get that bearing from the dealer, and it only comes in a kit with all the other bearings.
Unfortunately, dealers only carry these kits for so long, then deem them obsolete.
The MRC part number (207SG9) means that it's based on a standard 207 ball bearing (207S: 35x72x17), with a snap ring groove (G), and a special feature (9), which in this case is a non-standard bore (31-ish). From the drawing, it doesn't look like the snap ring groove is necessary.
I checked a few sources today, and came up empty. I'll dig a little deeper tomorrow, but it may be that you'll need to have a custom bushing made to adapt the shaft to 35mm (or build the shaft up, and turn it back down to 35mm), and use a standard 207 ball bearing.
Another option is an NTN 6207/31 (31mm bore). If you can find one of those (I can't), then maybe you can fit it to the shaft with some emory cloth.
Good luck! :thumbsup:
I was rather dismayed when I saw the post you linked when doing research this weekend. I think the only option is to find a good used bearing or use a bushing to fit the 35mm bore. I thought about building up the shaft and turning it down, but then the governor would not slip over that spot on the shaft. To make matters worse, the 2WD version of the A904 uses a different output bearing than the 4WD version. The 4WD version was only used in Dakotas, Jeep YJ, Jeep CJ, and possibly some D100 trucks / Ramchargers. Not positive if the light duty trucks had 727s or the 904. I have seen mixed reports. The 727 uses a different bearing than the 904. So much fun! The later A500 used a different bearing also, mainly due to the 4th gear being in the adapter housing. The Jeep A999 really is a red headed step child!
Same part number as listed in the link by spankrjs and the CJ8 FSM.
May be worth a call :shrug:
I reached out to a transmission parts house yesterday, awaiting a reply.
Thanks for all the help!
I placed the “junk” bearing in the ultrasonic cleaner in some evapo-rust. Set the temp to 120 and after 25 minutes the bearing is now spinning. Not the smoothest, but not gritty feeling. I will probably pop the cage out and see if I can inspect the races and balls. If the races can be polished I will try to replace the balls and “restore” this bearing. Assuming the cage is not damaged (currently or during removal). There is a little bit of hope left for this bearing.
35C7E770-8208-4EBC-A881-936107BEAD6B.jpeg A213A9AF-F02A-4E1E-9112-F05175945FA7.jpeg
The black particles in the container came out of the bearing during the ultrasonic cleaning process. Not sure if it was locked up from junk (hardened grease) or rust.
EDIT - After a little more cleaning and soaking, this bearing actually feels better than the other one. This is a SKF bearing and the cage is a plastic. The other is a MRC and has a two piece metal cage with rivets. To service the MRC all of the rivets would need to be drilled. To service the SKF, careful pressure should be enough to remove the cage. If I service the SKF I will document the steps.
Time to start working on the sub-assemblies. Pump first. Remove the two (02) sealing rings. These rings overlap on the ends and interlock. Use a pick to lift one up and unlock it. Once unlocked it will spring open. Gently pry it apart with your fingers and slip it off the hub. Inspect the ring for sharp edges and inspect the ring land for wear and chips. Repeat for the second ring.
758EC41B-92D5-43C0-A5FB-D0A4FF6A056F.jpeg 3DE8C3A5-F589-4D5C-8E82-BF98745E7A3A.jpeg
Remove the large seal from the perimeter of the pump. Clean the pump body.
F69A47ED-2E42-41E4-AA6E-7343E942EBD1.jpeg 489BC88C-2F37-47A5-9875-393781B78F19.jpeg
Remove the six (06) pump body bolts that hold the two halves together. I washed the pars in mineral spirits and placed them on a rack to air dry.
6230EEA4-DD57-44E4-AEF3-D4088235BE57.jpeg AADD1FAD-FDBE-4AA7-9921-E6A0DD2C25D1.jpeg
Inspect the rotor and gear for scratches or nicks. Any damage will require replacement and probably replacement of the pump body as well. Check the rotor to pump body clearance. It should be .001 to .003. Smallest feeler gauge I have is .002. It did not fit. I think it will be fine.
2406D0C7-3BC6-491F-B18D-56E86DBD8A9A.jpeg 48AC8916-DAC9-4A93-A085-615C9573224C.jpeg
EDIT - be sure to remove the old pump to case gasket, I failed to remove it until the pump was rebuilt. Doing this risks gasket material falling into the fluid passages that feed the transmissio.
Check the torque converter hub bushing for wear or scratches.
Mine has a small nick in one spot on the edge. (Top of the bushing in the photo.) I will be replacing it due to this damage. Th e seal looks good, but it will be replaced due to the bushing replacement. Shame, it looks like the original bushing with the nice stakes.
Check the thrust washer that mates with the front clutch assembly. It should be .061 to .063 for the A904 transmissions. Mine measures 0.062”. Right in the middle of the spec range. It does not have radial wear. Appears to have machine mark that are side to side.
4989314D-E3A2-4B36-BED4-92F39B22F95A.jpeg 06A0CDD5-22C4-45EC-AA90-3AA14030EDC2.jpeg
Random photo of the other side of the pump after cleaning.
Now, take a little break and play keep away with the dog. He grabs the ball and runs around you teasing you with it. You try to grab it, he runs away. You turn your back, he runs up to your feet, you grab for the ball, he runs away. Rinse and repeat until he is tired.
Small progress, pulled the TC hub seal and pressed out the TC hub bushing.
Original seal is marked 3-432 CR 4269057
Seal from the kit is marked P.I. 12575
The new bushing is marked 953 SAP 33383
Old one only has this proof mark
Fingers crossed I can press in the new bushing. The interweb is not encouraging on the ease for installing bushings in the A904.
On top of that, I probably could have left the original. All of the marks in the face correspond to where the ends of the bushing were joined. Hard to see in the photos, but it is a wavy line on both sides. Good to replaced it anyways, complete copper showing, meaning the top layer has been worn away.
DE24254C-F635-4567-814D-84CEFAE21A74.jpeg 25B18CAA-6457-4B82-9A81-D049A79D6645.jpeg
TTFN
Interwebs was right, not a fun process. Will need to get a couple more bushing to keep trying until I get the art of installing down.
11296BDA-A4A3-4D5D-A42A-4C3E0068DBB1.jpeg A057B57D-F67B-46AE-B0AA-37FD779A8B68.jpeg
Did some more preliminary disassembly in preparation of visiting a trans part house tomorrow.
Front clutch has a broken snap ring, and has 5 steels and 5 frictions.
0F5C098A-5D3E-497B-A6C9-F92D2121C6FB.jpeg C07077F5-B616-4105-9AAE-FA0324198BC6.jpeg
Rear clutch has 3 steels and 4 frictions.
My rebuild kit has a set of 3 steels and another set of 4 steels. It also has two sets of 4 frictions.
Alto 027706/224669 (rear) and Alto 027700/245894 (front). Steels are all Alto 027701.
Need to get an extra 027700, also need one more steel. Would also like to get a new double wrap band for the rear drum (Alto 027953 or 4431406).
F652EE8B-6573-4507-82FF-7DDA96622432.jpeg AFB61567-18B6-4867-9EB7-FBDDD19B3B8C.jpeg
Here are the Alto catalog pages for the A904
A3A5D0F3-B97C-4343-BE75-864FC60BA548.jpeg 91B1AA64-6D51-4358-A0F7-E6972393C6C6.jpeg 962CFC65-1FCB-423B-B20A-E7589C359FF1.jpeg
I place an order with A&A Transmission. Ordered bearing number 12272A, which indicates the correct shaft size. Just not sure of the outside diameter. Worth a try?? Interesting the ‘62 - ‘71 uses the Jeep shaft size, but the ‘72 - later use a different size.
Nice! I'll bet the OD is correct. I see alot of variations in shaft sizes for bearings, but the outside dimensions are usually standard.
Went by two transmission parts houses. WIT & PTP.
First was WIT (Whatever It Takes) Transmission Parts. I picked up 2 pump bushings (Babbit), Clevite part number 01998, 5 front clutch frictions BorgWarner 805*P2288, rear band Raybestos Q076 1453 (double wrap, 2” wide style), cup washer (race), and 2 cans of cooler flush. They did not have the washers (tab washers), nor the output bearing.
Second was PTP Transmission Parts. This place was recommended by the first, PTP stocks “B Parts” that are obsolete. Guess the A904 parts are “C Parts“. They are ordering a washer kit and tracking down the 12272A bearing. They might be able to get a NOS bearing, but if not should be able to find a good used one. We shall see. All I got there was a bottle of Valve Body Lubricant.
I forgot the additional steel I need. Oops. I got 5 front frictions because I don’t like mixing products in a single application. I don’t mind Alto in the rear, BW in the front, and Raybestos band as each is a different application and generally work independently. I say generally because some apply at the same time for specific gears.
If I get time I might go by Transtar Industries to see what they have.
