76k mile service time: engine oil and filter, rotated tires, and greased the steering and suspension zerk fittings.
I also sucked out all the PS fluid I could out of the pump reservoir, refilled it with fresh fluid. No real reason, just maintenance. Since this Jeep runs oversize tires, front locker, and goes wheeling, figured some fresh fluid every oil change might help prolong the new steering box and pump. Fluid is cheap and easy.
I have been running 75-90 weight gear oil in the Dana 300, Dana 30, and AMC 20. My rear axle has a few minor seeps, mainly the diff cover gasket, Ox Locker shift cable entry point, and a hair from the drain plug. If I park it in the same spot in the garage it always has a little spot. Never have to add fluid, not really worth all the effort of pulling the Ox Cable and diff cover.
A quick look in my '85 Spring Special Owner's Manual, interesting:
Since I do frequently tow a small trailer, and drive this thing on 8+ hour highway drives frequently, decided to drain and refill the rear differential with 85-140 gear oil. Will be interesting to see if the slightly thicker oil slows the seeps. Worth a shot!!
I noticed my rear passenger wheel hub seal was leaking some grease. Cleaned it off, will monitor, might need a new wheel seal here.
I also have some new windshield wiper linkage to try out and a few other minor projects I need to do. I have been daily driving this one since July, so I don't want to disable it. Been working with my tools at work, helping the owner's sell everything off/fix some issues at the wood working shop/get ready to shut the business down. A little while longer doing this, then time to get a new money making gig!!
That's it for now
