- Portsmouth
- NH
Need some advice from the crowd. I am going to separate the tranny from the motor this weekend. Due to bad planning, I need to drop the transmission vs pull the motor (will set this up slightly different next time).
Since I don’t have a lift, my plan is to remove the driveshafts, unbolt the tranny from the bell housing, unbolt the crossmember and lower the transmission. My thought is that it will be easier to maneuver the transmission under the Jeep without the bell housing attached.
Thoughts from the experienced crowd? Should I support the transmission and separate it from the crossmember before lower the transmission? Any other suggestions?I’ve never done this before.
Awesome trick with either version and I've done it for a few different things that have multiple mounting holes that are difficult to line up.
