sdsupilot
- OKC
- OK
Which fuel filter are you using? Does it have a return line? Some fuel filters have an internal pressure regulator that can return to the tank. I would check there or bypass the filter and check the PSI at the rail before dropping the tank. What PSI does the Ford EFI require?
