MrBeep said:Nice looking engine & trans!![]()
revho said:when did you get a cub scout?
That would be twmattox's old sticker. I'm sure I'll eventually remove it. BTW, you should stop over soon, Kevin. The pole barn progress (organization is really coming along. We also have some car seats to give you if you can use them (we'll call or PM you via greatlakes).
Today, I got the power steering box, brake lines, exhaust hanger bracketry, etc. removed. I'm on-track to have the frame hot-dip galvanized on July 30th. I'm just now researching primer/paint options (I already talked with Finish Master about some PPG paint options), as I want to paint the frame semi-flat black for a factory look. The galvanizing will protect it, and the paint is mainly for aesthetics, although it will also help protect it.
luvinmyjeeps said:your build is looking really good...
trust said:Craig, awesome project, i wish I had your meticulousness and stick to it ness, My one and only frame off was never fully finished (didn't get the window washers installed) and the restoration on my wife's 59 MG has stalled, again. Regardless, what really intrigues me is the diesel conversion and the home brewed bioD. I was toying with both myself although I had thought of going withthe Cummins BT4 although the SD33 might work better with my in situ 999TF. I'm really wondering if you are finding issue in collecting the WVO to refine, I have been seeing here locally that recyclers/biod makers are paying nearly $3/gal for waste grease and oil, better than the $4.80/gal for conventional diesel here at the moment but not exactly a huge bargain once the rest of the costs are factored in. Plus, the TWO fast food restraunts in town (yes there are only two) are both under contract as are all of the rest (maybe 5-6 other sources). Did you work out a contract with someplace(s) to remove their waste oils or have a friend/relative with a source or??? Seems like you will be producing way more than you need personally, do you have a storage method to ensure the refined fuel remains 'good'.
Sorry to take this so far off topic but it's darn fascinating and again, I have been so impressed with each of your projects to date that i know the bio production will be done right and is well thought out.
thanks!
tr
I sold my Inca Gold Scrambler before it was even on the road, as I just got burnt out on it. There have been other deserted projects along the way. I'm trying to see this one through.trust said:I'd love to make my own, I have a VW deisel that my daughter was driving too, but the initial cost, the availability and the lack of space all sort of dampen my enthusiasm.
Hmm, I thought the 727 and 999 shared a common bolt pattern, or is it a non amc 727 you are using? Thanks for the info. Having the drivetrain in hand would make the decision process much easier! lol I know it did when I was starting my other, abandonded, scrambler, the 304 and 999 in the garage were hard to ignore.
Excellent work my friend, keep it up!
Yes, there are barriers to entry (financially, time-wise, etc.), which is why everyone won't be doing it.
I read that the 727 behind the diesels is a Mopar big block bolt pattern and, then, has an adapter, too.1x1_Speed_Craig said:The TF-727 internals are the same as a normal 727, but the bellhousing bolt pattern is an oddball motorhome pattern. Scouts did use a T-19 4-speed manual, but you'll be hard-pressed to find a non-International 4WD auto transmission that would work. NOTE TO SELF: Pray the transmission case doesn't ever get damaged.
John N said:I read that the 727 behind the diesels is a Mopar big block bolt pattern and, then, has an adapter, too.
I bow to the master on this....1x1_Speed_Craig said:The big block Mopar thing was discussed on the CJ-10 Yahoo Group, but it was determined (last I knew) that this was not the case, and that it's actually a motorhome bolt pattern, which is different. And yes, there is a ~2.5" thick adapter between the SD-33 and the transmission.
Craig
John N said:I bow to the master on this....![]()
