An update on the "Slowest Scrambler Rebuild Thread". Yeah, I know, get busy. It's just that Life keeps happening... But, I do have some progress to show.
Here's a look at the Ected front locker...
Front housing installed. I'm planning on either flipping the u-bolts, or getting u-bolt skids. But for now this will do.
Pressed new ball joints in the knuckles. The pass knuckle was machined for high steer, because I didn't want to have to relocate the steering gearbox. Used a shorty arm- going to get a corresponding flat shorty arm for the gearbox.
Driver's side. (Yeah, I'm missing a stud.) It's the brother of the right knuckle- Chevy stuff. Had the flat top studs already installed. Do you think I should install a cut-off arm over the studs? Might help with rigidity- or at least keep the studs from getting buggered up.
Here's the reason for the hi-steer on a SUA setup. The D44 moves everything forward. Under compression, a standard drag link would end up interfering with the tie-rod. Not to mention bump steer. This way, the drag link and tie rod should stay mostly parallel. I need to replace the drop arm for a flat arm. PartsMike has them.
Well, now that I've shown yesterday's progress, it's back out to the shop. Going to play with the engine/clutch/trans adapter today. Supposed to be close to 100* today- phew! I was going to go to the Groundhog Rock Crawl yesterday, but 3 hours of driving to bake in the sun didn't seem to be a wise idea, especially when I need to get this baby running!!!
