- Redmond
- OR
Thanks for the kind words and wishes. They worked wonders...
So, got out and finished all the small stuff. Mounted the evap canister, behind the rear wheel well next to the valves.
Got all the engine wires cleaned up, sheathed, and ready to go.
Then I put some heat shield material over the fuel filler hose cover, over the tank and on the frame where the exhaust is close. No pic of that...no pic of putting 15 gals of fuel in the tank, either. I hooked up my prelube contraption and pumped 6 qts of Mobil 1 in through the block port before the filter, turning the crank slowly as the oil pumped in. No dry starts for me. I installed the battery, turned the key to run, and checked for leaks...none!
So, it's 5:00, and a thunderstorm rolls through. Huge raindrops, and the thunder was awesome. A huge thunderclap echoed through the garage, and I figured that was a sign. I reached for the key.....
