Made it to Michigan, wheeled the dunes, and made it back in one piece, which is always good. However, on this trip, unlike most others, I had quite a few "issues", but nothing major. So, this update will be of the problems I encountered on this latest cross country trip.
#1) Fuel issues still occur. The new fuel lines did not fix the "hot fuel" problem. But, like usual, only occurred in MS and AL. Once I was in/north of Tennessee no problems. While down here, every two hours, like clock work, at 75-80MPH on the interstate, I would get the "slight stumble upon acceleration" problem. Ten gallons of new fuel added to the existing tank would immediately fix the issue.
My next attempt to fix this issue - move the fuel filter to the downhill side of the fuel pump. For some reason I placed the filter before the pump on this Scrambler. My red Scrambler, which does not have the "hot fuel" issue has the filter after the fuel pump. This will be a cheap/easy attempt to fix this issue. I still do not want an in tank pump, especially seeing the problems Truck had.
#2 Don't try to fix the gas gauge at 75 MPH!!!!!!!
The gauge was stuck on full, so I decided to pull the sender wire off the back. The only problem, I pulled the back half of the gauge off!!!!!! Easy fix, the gauges is made to come apart like this. But, I will have to pull the speedometer housing again.
#3 I had some slightly loose steering feel, which is odd, considering I had no problems on the South Dakota trip. Anyway, second gas stop in north Alabama, I checked the front wheels, slightly looses spindle nut on the passenger side. This was kind of odd, the outer nut was still super tight, the inner nut backed off a hair, but a quick easy fix:
The freshly tightened/adjusted wheel bearing cured about half the looseness. This particular steering box looks original, and if it is, it has over 170,000 miles on it. So, at a gas stop north of Indianapolis, I jacked both front wheels off the ground and adjusted the steering box. This cured the remainder of the "loose steering" feel. On the adjustment, I held the center bolt still with an Allen wrench, backed off the jam nut about five turns. I would then very slightly tighten the allen bolt, then check the play at the wheel. Once I felt slight resistance, I stopped tightening the allen bolt and backed it off 90 degrees. It does not take much tightening to eliminate the lash, BE CAREFUL. Worked like a charm.
#4 Not sure where this happened, but somewhere on the trip north, my driver side motor mount parted company with the rest of the Scrambler!!!!!!
I could "feel" a slight "wiggle" upon acceleration/deceleration on the road, but nothing strange, no vibrations. I didn't even know this happened until I went up Test Hill at Silverlake, heavy acceleration in 4wd, I could here a banging. This was another easy/cheap fix. I had to get an "older guy who doesn't only rely on computers" at the parts store to help me find what I needed. A $6 box contained two new round rubber mounts, and a new bolt from my spares fixed this issue. But, I think my current mounts are kind of suspect, so I will be upgrading these soon.
The missing motor mount caused the motor to drop some, which did cause the PS pressure line to contact the steering shaft, and the exhaust manifold also made slight contact:
The replacement motor mount eliminated the contact. The pressure line is not leaking, but i need to take a look at it to see how much damage happened to it. I will probably get this line remade, with a longer piece of rubber, to better clear the steering shaft.
#5 This is another "mystery" problem. I put all new brake pads/drums on the back before South Dakota. All new springs, the self adjusting hardware looked fine. Well, after racing BigWalton, my brake pedal got real soft, like I blew a line. No lost fluid though. The brake booster vacuum line grommet looked "suspect", so I "borrowed" a grommet from Dustin's sister's Scrambler. That did not fix the problem. The next day, while trail riding, started hearing a grinding, sounded like it was coming from the front. After further investigation by hitting the brake pedal a bunch, something sounded strange in the PS drum, like a broke spring. Went back to camp, pulled the drum, found this:
The self adjusting hardware fell off? The adjuster was all the way backed in???? It DOES have the correct adjuster on this side, so I am not sure how this happened?? I had to straighten one piece out with a hammer, but it all went back together just fine, and has been holding the adjustment. So.................................. But, another cheap/easy fix.
#6 This is more of a severe aggravation as opposed to a problem, but the back suspension feels way too loose. And again, no problems at all during the South Dakota trip, and the Scrambler was hardly driven between the two trips, and was not drove hard.
After South Dakota, I actually pulled the entire rear suspension apart to check for problems. The u-bolts were fine, the shocks were fine, the spring packs looked fine, and the center pins, though very slightly "s' shaped seemed OK.
I only carried maybe an extra 100 pounds at most on this trip, but the rear is just way too loose feeling at high speeds/moderate cornering. Feels squirmy, if that makes sense. The front end is fine, sway bar good to go.
So, I will pull the rear suspension back apart and look for problems. Maybe a center pin or spring broke?????? If no problems are found, I might add an "add a leave to each pack". I am going to drive the Scrambler unloaded first, to see if this issue is load related. But, I probably only had 250-350 pounds in the back at most, not like it was overloaded. Moving the 5 gallon gas can/ice chest from the rear bumper rack to the bed did help this issue some.
All in all, a great trip. A few easy/cheap fixes and all was good.
A few "fun" pictures:
After the "midnight sand paddle tire fairy" visited/struck:
Country Dairy:
Tim's Scrambler next to mine at the top of Test Hill:
One big group shot:
I will update on the fuel/suspension issues, that's it for now
