trust
PITA
- White Rock
- NM
GREAT thread, I've been thinking hard about the Cummins for mine when I repower, thanks for sharing, I can't wait to hear your impressions and what kind of milage you get out of the motor.
As far as the gauges above the factory ones, I did that with my cj5 although I did start with a blank dash rather than the factory panel, In order to get around the interference from the 'defroster' duct I got an ABS unit from Qualitydraft/AEMiller and massaged it with a heat gun to clearance the space behind te dash. It didn't noticeably impact the defroster effectiveness, but then how could it on a 74 CJ 5? Just a thought. One thing I am planning whenever I get around to it is to add a gauge panel (electronics project box) to the dash bar of my roll cage and put the gauges and a switch panel in it. Also, you can get individual gauge buckets that clamp to a roll bar tube from Summit or Jegs, but you need the roll cage tubing to clamp it to.
