Not the most exciting update, but an update.
The engine oil was getting pretty dark, so decided to add some flush and change the oil and filter.
Used this stuff, have used it before with no problems:
Seems to be a common picture of this Scrambler, hood up!!!!!!!!!!
After adding the flush, and changing the oil, the old oil that came out was jet black. So, hopefully the engine flush stuff cleaned up most of the old carbon build up. There was a little bit of "sludge" in the bottom of the drain pan, not too much, though.
My current "punch list":
1) Choke does not always set when you first fire it up. Need to adjust the spring tension (maybe), or make sure nothing is fouling the mechanism.
2) Valve cover is leaking at the front a little bit, hopefully just a screw needs to be retorqued.
3) Clutch has too much free play, easy adjustment.
4) Parking brake, pretty sure it just needs a tension adjustment.
5) Grounds, grounds, grounds, grounds...................
6) Just need to work up the courage to drill a few more holes in the side of the body tub!!!!!!!
7) Have the piece, just need to swap it in.
8) Oil pressure gauge reads 40 psi, even with the sender wire un plugged, will see if I have another old OEM gauge to swap in.
9) The source of my drip on the cardboard is from the oil pan drain plug, it just needs a new washer/gasket.
After that, a quick wash, then get this thing out of here!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
That's it for now
