- Biloxi
- MS
Do they look like this???
That's the style I ordered![]()
Oh no..no ..no... you've got to try at least one sticker yourself. My buddy got me started and I did the rest, only because I couldn't wait. Be patient, cut all stickers out with scissors, use masking tape to center, measure and re-measure and make sure its where you want it. I think I used 2 inches up front on Scrambler sticker and 4 inches at back of Scrambler sticker. I think.. Measure out with tape, top bottom left and right. Use a bottle of water with dish soap drops in it. It reduces the stickiness of the glue on the back. (Too much water and you eliminate the stickines of the glue entirely--I used alot and had no problem- like dripping). Spray the body, AND then the back of the sitcker without paper-- liberally and you can move it around and place it where you want. Don't put sticker on body dry-- it'll stick and not come off. Use soapy water. Biggest issue for me was meeting front fender sticker to stripe at bottom. Don't make gap too big. (And they didn't line up top to bottom-- align with top because that's what you see).
Don't do it in the sun; do it in the garage in the shade where body is cooler. You should have plenty of time to mount it where you want it (like many minutes) and then squeegee (not spelled right?) getting all bubbles out. It'll lay down more within the week. Use a razor blade (buy a box) and use them liberally. Press into sticker to cut; do not slice into paint-- just press into sticker and it'll cut off on its own. Next day take a pin and puncture the small bubbles and press down and they will disappear.
You can do it. Look at a bunch of pics up close for details. My rear-most stripes are a little higher than the rocker stripes buts that's the way they appear on all of them. Start at the rear with the smallest stripe. Try it! You'll probably do it better than a body shop...![]()
I saw your scrambler project on another site and I am amazed and can only hope that some day My scramblers will look as good as yours. where did you come across the whitco soft half top? have you decided if you are going to mount it or the full top? if you are not going to mount it I'd be powerfully interested in buying it from you.
I thought all sliders had those spacers, without the spacers the sliders would bind. I had to do some leveling on my stock setup also...
How doe you like how the tire rod flip ended up? Do you feel 100% confident in it's fit? Reason I'm asking is I need to flip my pitman arm end, and the drill and weld inserts are prone to cracking in this position. Your kit looks like it takes advantage of the OE strength... Would you consider loaning out the reamer for a small fee?
His blasting machine wont remove the paint
I think you'll have it rolling outta there this weekend! Work looks great. Will the foam tape on the bottom of the bulkhead hold any water? That might not be good, but I did not have one in mine so I don't know what the factory used.
Also, might want to consider some clear tape (3M makes it) to cut and install on the sills on the doors. As soon as I got in mine I (or someone) scraped a shoe across the sill. I bought a roll at a surplus store and cut to length and width and installed. It's clear so can't see it but it protects it from scratching and it's removable and replacable. Also, have bought it a Walmart in a small package.
Keep at it, looks great!
Looking great!
OOOOO PRETTY! Makes me inchin to start my frameoff.
I will warn you, though, it takes a bunch of work to get it back to this point, and I'm still not "done"
