I worked on the front output shaft last night, got a bit more done.
I installed the two shift rod thimbles, sealed them to the case with some of the hardening sealant. I also installed the rear bearing retainer plate with the original shim stack, as a starting point. Surprisingly, the paint I used on the bolt heads is holding up pretty good. I must have installed/removed these bolts about 20 times last night, while adjusting end play, and they still look pretty good.
I then bolted on the front bearing retainer thing. I did not use any sealant at this time, on the front or the back, since I have to take things on and off to adjust the end play. I also did not have the front seal installed at this time.
Quick picture of what the assembled/bearing supported front output shaft looks like.
I added one super thin shim to the original shim stack, and had a reading of around .004-.005. This is within the factory recommended range of .001-.005, but it feels kind of loose with this much play IMO.
This is where it gets kind of tricky. The FSM, nor any other literature I have seen, ever recommends sealing the shim stacks together/to the case/to the bearing retainer plate. I always do, because I do not want leaks. So, this is what I do, don't know if it is "correct", but so far, it works for me.
First, I pulled out the super thin shim I added to the "presumed" factory shim stack.
Next, I use the below pictured stuff to coat both sides of each shim, the face of the transfer case, and the face of the retaining plate. Basically, I "glue/seal" the shims, retaining plate, and transfer case together.
The pictures make this sealant look thick, and it does go on thick. But, when you bolt it all down, the excess will squeeze out. So, technically, by adding sealant, you are increasing the thickness of the shim stack by a little bit. Not much, but some. And since we are talking about .001's, a little is a lot. So, by removing the added thin shim (decreasing the overall end play), but then adding sealant (increasing the end play), it gets tricky. Basically, I want to start "tight" (around 0-.001" end play), then by adding sealant, get it a hair loose (.002-.003"). It takes a little trial and error, and the sealant does not set up instantly, so worse case scenario, you can pull it apart and play with the shims, if needed.
And after all of that, the assembled front output shaft end play is .001". This feels "good", and turns nice and smooth. I am happy with it.
I still need to add the anaerobic sealant to seal the front plate to the case. Technically, this "could" increase the end play. But, that sealant is super thin, like razor thin once you bolt stuff together, so no worries.
But, before bolting the front down, I need to install the shift rails. I started to last night, and they kicked my butt, like usual.
That's it for now.
